Hey there.. I dont know the answers to your questions, but I am wondering where you are getting your Vossens at?? I am thinking of picking up the vvs083 or vvs084..redline122 wrote:Okay... after much thought, I went back to the drawing board on my mod strategy.
1. Really like the BBK - the look and the potential performance improvement (G37 BBK with Stoptech D/S and Goodridge SS lines) - 4 hours of labor according to my installer (better than the dealer estimate of 8 hours).2. Want to avoid the use of spacers (sz...I think you will be happy to hear that... and it does make sense... why introduce another possible point of failure)3. On the thought of #2, considering getting Vossen VVS-085http://www.vossenwheels.com/vo....html >> 20x9, +38mm offset on the front running 245/35R20>> 20x10.5, +45mm offset on the rear running 275/30R204. Lowering the car with Eibach
My concerns are...> None of the installers really knows if any Vossen wheel will work flush with the fender with the BBK setup on the M.
> Is running 275 on a 10.5 okay? Should I consider going with 285/30? Would this slightly wider tire rub into my fender? Look strange?
> Maybe I should consider running stock height until I get the BBK and wheels put in. Just to get a feel for those mods?
Your thoughts?
My old set up was >> 20x9, +30mm offset on the front running 245/35R20>> 20x10, +35mm offset on the rear running 275/30R20 using Eibach springs and I had no issues rubbing and they were pretty flush in the rear not in the front, but now Im running coilovers about a 3.5 inch drop all 4 and running 225 35, and 255 35 tucked under the fenders VIP Style and 10mm spacers in the front and 5mm spacers in the rear the front rubbs every so offen when i make a u quick U turn, from the top view my lip of my wheels stick out but the tires are streched so they fit under the fenders so it looks Hella Flush!redline122 wrote:Okay... after much thought, I went back to the drawing board on my mod strategy.
Your thoughts?
Here we go: http://www.1010tires.com/WheelOffsetCalculator.aspBTW, i am in on a group buy for a set of Vossen's. I am still working on a deal with a forum member here on a 20" setup, but I am also open to other suggestions. Don't need the wheels at all since I have a custom 22" setup on my ride right now, but always entertaining a decent deal so that I can switch when I get bored. Let me know.redline122 wrote:skim - nice pic in your sig! It seems that there isn't an exact science in my quest for fitting an aftermarket wheel with the BBK I am planning to put in. I wonder if I know what I am doing with all this.
>> Maybe someone here can direct me on understanding how to properly calculate offset and clearance given the setup I am going for.
Thanks redline122 good luck with your purchase!redline122 wrote:skim - nice pic in your sig! It seems that there isn't an exact science in my quest for fitting an aftermarket wheel with the BBK I am planning to put in. I wonder if I know what I am doing with all this.
biffed wrote:Redline.. I sent you an email
biffed - we are on the same wavelength, brah!biffed wrote:he question of the day for me is.. What springs is he on.. tein or eibach??? Please do tell sir..
Spacers?! Really?! Why stop there... and put a big fat white racing stripe down the middle of the car.Petrol head wrote:...use a spacer on the front wheels if you have the room .....
