BDub13 wrote:I am looking at some new rims and tires or my 93 TT 300. Just wanted some opinions from other people who are speaking from experience because I font want to regret my choices. I was thinking 18x9.5 on the front, and 18x11 or 12 on the rear. I want a 25 or 30 sidewalk on the tires, but I am unsure what widths will fit on those tire sizes. I also would like some help with offsets so that the wheels will be flush with the fender wells, but not rub when I hit some bumps. It is currently lowered by 1.5 inches all around.
Just another quick question, I have heard that replacing the intake pipes with hard pipes causes a sensor (I think it is the MAF) to vibrate and send inacurate data leading to a bad idle. Is this true? I was wondering because I was looking at some BOV's and I think those only work on hard pipes? I want them just because they will help things run smoother and sound awsome. I have always been confused by BOV's Vs. Wastegates, so if someone doesn't mind giving an in depth description. Do they both make the same cool sound??
I was also curios as to how they get the horsepower rating from the factory. I mean, how much boost are they running to get the numbers they do? Are all turbo'd cars tested at the same boost so that they are comparable or what?
How much boost is a safe maximum on a stock VG30DETT?
Thanks for any answers u can give, I would really love some answers.
I think 11 or 12 inch wheels in the rear may be too much without rolling and pulling the fenders and maybe some negative camber. The front should be fine depending on offset. If you search around, you will find the answer.
I have never seen where hard pipes on the motor cause the MAF to vibrate. Both are isolated from each other.
On BOV's - you are actually better off without BOV's and keeping the stock recircs. The BOV's let air out of the system (unless you have the recirc kit) the MAF has reported. Some have had issues when they shift due to this, some haven't. But, you don't need hard pipes for this, you can put them in place of your stock recircs.
BOV's and Wastegates perform different functions. Wastegates open to allow excess exhaust pressure to release in order to manage the boost levels of the turbo. BOV's open to release excess intake pressure to keep from "compressor surge" when the intake air is highly pressurized and causes back pressure on the compressor side of the turbo. This usually happens when you shift of let off the gas and the intake stops accepting air. That pressure has nowhere to go unless the recirc valve or BOV releases it.
Hope this helps.
Also, TT.net is a great site, but you better search thoroughly BEFORE you post. They will rip you a new one if you don't. You should always search first anyway. But, I took mercy on you
