Rims AnyOne??
BenzTech Gone Versa
Car: 2007 Nissan Versa 1.8SL
Check Out http://www.Tirerack.comPut In You Veh.Info And Hit The "WHEELS" Button And Whaalla.They Even Let You Pick The Color Of Your Versa So You Can See What The Rims Look Like On Your Ride...Sweet.
ilusha55
oh yeah...great sitesome results with 18inch rims, i feel bad now
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I bet you could fit 18" wheels on it. Not sure why you'd want to...but you probably could. I've test-fit 18" wheels on my older Maxima that has the same diameter stock wheels/tires as the Versa and the set I was fitting actually looked good (non-chrome!).
civilone
Car: 2007 Nissan Versa (Ebony)
Black on black is pimp!
BenzTech Gone Versa
The Rims In The Middle Pic Are Bangin'.The Lip On Them Is Like Oversized 300C Rims!HOTTTTTT
threeinchblitz
Car: not drifting
Does anyone know if the nismo wheels from a (B15)sentra will fit on the Versa. I am ordering a Versa in January( or whenever the sports package comes out ) and if able to will be putting my Nismo wheels on the versa off of my Sentra, thetire size will be 215-45-17, I normally run a 225-45 on the Sentra but think that may be too wide for the versa.
any suggestions?
Jemdawg
Car: Super Black Nissan Versa 1.8SL Hatchback
17" x 7.5", less weight and much better handling.
threeinchblitz
Car: not drifting
Well I already have the rims (5 actually including the spare) im just concerned for the fit, the tires are pretty thin on that car i think 185 wide to push 215 seems like on hell of a jump, in terms of clearing the struts and not rubbing on turns, I will have to check the offsets and see.
Jemdawg
I'm going wider but I'm going to replace the springs and struts at the same time.
MIdnkight-lude
MinisterofDOOM wrote:I bet you could fit 18" wheels on it. Not sure why you'd want to...but you probably could. I've test-fit 18" wheels on my older Maxima that has the same diameter stock wheels/tires as the Versa and the set I was fitting actually looked good (non-chrome!).
i dont know i test fitted one of my old prelude 17's gunmetal rim to check out size and see if i should go lighter or darker rims. the tires for the versa might need a bigger profile tires, which is good since that means less bent rims for me.
I now want 18 on the, but i will most likely stick to 17 or less for weight issue, now i am thinking of trying out black rims. :P
And the Versa has to be lower if you want to get some nice rims. grrr more money to spend.
BenzTech Gone Versa
For A 17 Inch Rim It Looks Tiny On The Versa.Make Sure You Don't Throw Off Your Wheel Sensor(tpc) Or The Speedo!
MIdnkight-lude
BenzTech Gone Versa wrote:For A 17 Inch Rim It Looks Tiny On The Versa.Make Sure You Don't Throw Off Your Wheel Sensor(tpc) Or noThe Speedo!
haha not even one day old and it was wearing new shoes. haha. i had a old set of 17's rims from my prelude. The offset is nice, but yes the 17's are small but it has a lip, so it looks smaller. But the tires need a larger profile, because i check the gap and the stock sit taller then my 17's.
grrr choices choices, i want rims now!!!
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Have fun fitting 7.5" wide wheels on the Versa.
MIdnkight-lude
MinisterofDOOM wrote:Have fun fitting 7.5" wide wheels on the Versa.
those velox i test fit on my versa are 6.5 inch wide. as long as the offest is right the rear should clear as long as you arent slam. the front i dont know.
red98s14
MIdnkight-lude wrote:those velox i test fit on my versa are 6.5 inch wide. as long as the offest is right the rear should clear as long as you arent slam. the front i dont know.
These are 7.5 wide, 40 mm offset. Tires are 205/55 - 16. There is just a couple mm clearance to the suspension at the front. At stock height no issues with the body.
Edit to insert image, duh
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Mmm... 5-spoke hawtness!
http://www.miata.net/garage/tirecalc.html... Miata tire size calculator FTW! (calculate the correct size replacement tire to keep your speedo accurate, and get the same overall diameter tire)
