Rims and wheels
Dragon_284
Hey what is the size of the stock wheels on a 1990 240sx. Also would a set of stock rims off a 1991 240sx fit on the 1990. The bolt pattern for the 1991 rims are 4 lug with 4 1/2 inch apart. Last but not least is there an advantage to upgrading to 5 lugs for the 240 or does the 4 lug pattern work better worse etc.....
Thanks for the help.
eddiec
Car: 91 S13
i think all the 4 lug 240 patterns are the same. so yes you can swap different years out.
one advantage i can think of for doing a swap is more wheel choices. i'm sure there are others as well.
