Hookm36 »
https://forums.nicoclub.com/hookm36-u62339.html
Fri Dec 28, 2007 7:40 pm
I have upgraded to 19's... 8.5 in front and 10 in rear.. The Tire presure censor...from my understanding is connected to the valve and actually sits inside the tire itself..... the censor sits in between the inner part of the rim and the inner part of the actual tire.
When i purchased new wheel/tires the company had them already balanced and mounted for me so when i arrived they would just swap......but then they realized I had the tire pressure censor, so they then had to take the tire off the rim, add the sensor, re balance/mount and air up.....you will not have any problems.
