rims and tires
Schfifty-5
Car: CArs
Has anyone put 31 X 10.50's on an X-terra without a lift? I am just wondering if that is possible, or will I have to put a lift on mine. Hopefully not, I don't know if that would look to good or not.
Stormy
Car: What do you think?
Yes, you can put 31x10.50's on a 2000... You'll just need to trim the front mud flaps to prevent rubbing. Something like this...
I thinK the tires are 32's so you wouldn have to trim as much.
SmithSR
Car: 240sx
Please also consider what wheels you use. Rear spacing on most aftermarket wheels(for this application) will place the wheel/tire assy farther out than the factory wheels. Add a wider tire with a larger diameter to the mix and you can(will) have turning radius clearance problems which will need to be addressed with the cutting wheel, as described above. :)
STORMY: can you submit your ride to the MEMBERS RIDES contest, as described by Fred in his other thread? That thing looks badass!!
Stormy
I already did :)
