musashin wrote:Everything matters on offset. You're going to need it to be higher than "flush" offset; like something around 30, probably. If you pick the right offset, the 275's shouldn't be any problem. There are people running 315's on pulled stock body (S14) so just about anything is possible. I think the 255's would be much easier to fit on the front (you don't specify whether you want to do this all around, but since you want a drag car I'm guessing you don't want to run giant tires in the front).
yes your correct just one the rear i'm going to run these.
What kind of offset would i need to run these? i'm getting my rims widened from a 15X7 (0offset) to a 15X9
