sorrowfulkiller »
https://forums.nicoclub.com/sorrowfulkiller-u134601.html
Sun Jun 14, 2009 8:56 am
I'm trying to figure out which size fenders to get with my rim/tire size I want to run once I get an s13. I'm planning on running 17x9 +17 offset rims all around with +3mm spacers in the front and +10mm in the rear. Which should leave me with 141mm of backspace (the distance between the outside of the rim and the back hub of the rim), 134mm is stock and enjukuracing.com recommends the furthest out one go to be 142mm for the front and 141mm for the rear. Now I'm thinking if someone would go with a 225/40/17 with a +27 offset in the rear and +28 offset in the rear it would be pretty close to being at the limit to how far you could go out without changing camber.
If I go with a 255/40/17 with 17x9 +17 offset all around, with a +3mm spacer, essentially making the +17 offset +14. This would stick out 29mm further than the 225/40/17 +27, assuming no camber change. This should clear the suspension however.
My question is then... does anyone make +25 oversize front fenders so i could run 255/40/17 all around or am I missing something, would I be able to run those tires in the front with 20 mm oversize fenders?
Modified by sorrowfulkiller at 2:32 PM 6/14/2009
