Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat Jul 19, 2003 12:43 pm
dude, im not talking about the coil spring itself, the area the tire would scrub(the lower, thinner section of the strut, where the damper itself is) is much thinner in a standard strut than the coilover, whos body is much larger in diameter all the way down.
if this wasnt the case, why would wheel/tire setups that clear stock struts rub coilovers? just ask 240+keyy about it, or take a closer look at what I am talking about. Im not talking about the spring perch, which IS wider on the stock shock/strut, but the are benewath it, where the tires will rub if you go too positive with the offset or too wide with the tire(or both), this is where coilovers are wider, thus necessitating the added clearance so often spoken of.
whew. did I explain that well enough?
-chet
