Rim Question: will this offset work
jmwenick
Car: 1991 240sx Base Model
Hey guys, just wondering if these wheels will work/fit well on my S13 here's the specs: 17 x 7.5 JJ, 4 x 114.3, Offset 42 Let me know what you think.
Fenvy
Car: 2005 350Z Base 6MT
+42mm?
sounds like stock offset man
ILikeMy240sx
Car: SR Power
bleh... that offset makes me wanna puke.... Your rims will look terrible with your S13.. its going to looks like a sunken ship
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
ILikeMy240sx wrote:Your rims will look terrible with your S13.. its going to looks like a sunken ship
YUup, it'll look terrible dude. Get some lower offsets.
Fenvy
yeah look at bomex's car, that's probably 18s or 19s and maybe 10 or even lower offset
that 7.5 will allow you to put 245 tires all around per my understanding but the high offset might cause the suspension to rub against the tires
low offset, or even negative offset for the win
jmwenick
Ok guys, thanks for the replies. So what offset would look flush against the fenders 20, 25?
Fenvy
for 17s?
I am no expert but under 30 should be good
watch out for too low of offsets, the rims I WAS going to buy had -20 offsets and they will stick out about 3 inchs out the fender... just imagine going over a bump with something like that: the fender will cut the tires
or worst case scenario, going pretty fast on the freeway... a bump or a dip and then the fender STOPS one of the wheel while going 70+ mph
also, the measurement of the tire play a role in this. If I get skinny tires, probably won't happen, but if you're trying to get wider tires... you will start to have problems.
Consult the tire/suspension forum
BomexS13
'00 Toyota Celica
jmwenick wrote:Ok guys, thanks for the replies. So what offset would look flush against the fenders 20, 25?
20 should be nice..
sixxdeuce
Car: 93 rx7, G35coupe 6mt
If its only a 7.5 inch wheel you probably want closer to a +5 or 0 offset once the camber is set. 17x9's look good with around +10 in rear, +15 front, so you have to account for the smaller width and go lower offset if you want flush, but +20 will look nice just slightly sunk, shouldnt even need a roll for that setup.
Red coupe
Car: 92 Nissan 240sx Coupe
7.5 Id go for +35 to keep it close to stock because I dont care what it looks like, and Id rather let the guys who made the car do my planning for me.But for you I would go with BomexS13, look at his car...You know he knows how to make it look good 17X7.5 +20mm in 4x114.3 bolt pattern for teh win...
deCksy
7.5 i'd say 10mm is a perfect flush
i have 16x8 with 38offset and its sunk in like whoa... well not that bad but i'm a flush whore. so i have a 28mm spacer on there and i might get a 30mm so it'll be completely flushhh for JDM HoTneSs!!@!@#!#!$!$@#
and ive seen bomex's car in person... and it's hot and flush!
Modified by deCksy at 6:06 PM 6/18/2005
black s13
i guess my 195/205 stagger on a 7" wheel is a slight stretch then?
anything in a decent width, somewhere around +20 is nice. my wheels are plast flush, i have massive amounts of camber to clear the rear quarters.
Fenvy
it shoudl be alright but it's alittle on the skinny side
I have 15x7 and 225 all around, I am told it is even possible to put 235 but it gets to be a bit dangerous
ILikeMy240sx
Car: SR Power
my rims are 17*8 and +20 offset... lines up with the fender pretty nicely
black s13
Loveless wrote:it shoudl be alright but it's alittle on the skinny side
i was being sarcastic, sorry that doesnt come off too well on a forum.
i would like to run a wider tire, but my offset wont allow it.
Juujai
yeah anything under 25 will fit...
x9 +15-20~x8 +10~?x7 +0-10x6 ... dont even go thereyou can go lower if you're willing to roll fenders or pull, neg camber etc. but pulling too much looks gross like over sagging breasts. youre car your money though.
i think super wide 18s with negative offset, -10000deg camber and fender pulling looks disgusting but some like it... it's like a fat chicks chest bulging out...
Juujai
yeah ur gonna find out that some of the only affordable wide 17x9+ wheels with low offsets are: 5zigen fn.... and work emotion cr.
then ur choices will be either 15,16 inch wheels or 5 lug conversion =/
