Rim question
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Hi,
After looking at a few pics of pathfinder/QX4's with 22's . It seem there enough clearance to put on 24's . Just wondering if its possible to put on 24's on a stock setup.
W O T
Car: 2001 Infiniti Qx4
My 20's with 45profile tires would rub at near full lock with stock suspension
I would say no, but Im sure with trimming, maybe a small lift it would be ok
24's though man? Wouldnt last long in scarborough
02pathy
i honestly think that 24's will fit just fine, even with 22's i still have alot of clearance, doesn't rub n e where, make sure u get the right tire and rim size i think it's 265/75/85-30-24, check http://www.1010tires.com
W O T
"265/75/85-30-24"
I would not recomend a 30 profile sidewall for toronto/scarborough streets
I used to bend rims bimonthly with 35 series on my Crx, and that thing only weighed 2100lbs
Good thing is my town pays for damage done to your car if it happened in a town construction area (ie, just say you smacked a rasied manole or something0
02pathy
30 series on a crx have a 1" sidewall versus 265/30 i think it works out to 2 3/4'', not sure did the math last year, i drive around on the 35'' series with no worries of pot hole, with that size tire u ride over the pot hole
JonathanPrem
WOT went on 1010tires.com. Man it said i need 275/25R24 for 24's doesn't how thin is the 25 and 275 gonna rub on the fender. Btw where did you buy your rims from?
W O T
My crx didnt have a 1" sidewall, I didnt have riceboy tires lol, I had 245's on the front of that thing, need some surface area to pull 350whp in a tin can!!
I bought my rims off a friend of a friend locally, dont know where he got them from though
02pathy
naw 25 series is pushing it to much, stick with 22"s alot safer, for my car the sidewall difference is about an inch, i got my rims from centerlinewheels.com there overstock section
245 on a crx with 350, normally i would see 205 to 215 max with the regular 1.6, once in a while a b16a, b or 18a
Adnan
Car: 2001 Pathfinder LE 4WD
whoa! what kind of power train did you have in that thing?how did the 245s stick out? i went from 195 to 205 on my ejand i had to get my fender rolled in order to clear
about the rims honestly,22s are about the biggest you would wanna gounless its for show or BET bling factor
W O T
Had a B20/vtec sleeved with forged internals, exospeed worked head, crazy lumpy cams and a t3 .60/63 snail @ 18-20psi. Didnt sound like a Honda, was told many times it sounded like a Mack truck with the open turbo screaming and open downpipe and wastegate dump. Couldve made alot more power but i was maxing my injectors out. Cars been sitting for a year now I miss her. As for the tires sticking out almost 2" I bought some fiberglass wide fenders, looked "almost" stock lol. Definetely a sleeper when it was on the road, theres no cars in my area daily driven that were in the 11's.
Sorry to talk so much in your thread
