Rim Question again
Q45man1
Car: 2002 Q45, 1994 Q45
I believed it's been asked before.I'm considering putting in the M45 19" rims for my F50. Will it fit? I believe it has a +50mm offset. What is the upside and downside with this offset in my F50?
Thanks guys.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Won't work without spacers.
The 2006 Q45 did seem to have an identical wheel that did work, presumably without spacers..
Q45man1
What would be the right spacers size?
Thanks Brian
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Some have run 25mm on the similar FGY33 chassis.
Best to calculate yourself. Check BadQ45t posts for that information.
Drifting an F50? Surely there must be a better use of a fine touring car!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
According to wheelcollision.com, they have 2 different part numbers for the 19x8.5 Thin Double 5 Spoke SMOKE BRILLIANT wheel:
2006 Q45 Part#H 73690
2006-2007 M35/M45 Part#H 73687
If you email them, they might be able to tell you the difference in the offsets.
TgduMg
Car: 94 Q45, 02 Maxima SE
lino wrote:According to wheelcollision.com, they have 2 different part numbers for the 19x8.5 Thin Double 5 Spoke SMOKE BRILLIANT wheel:
No need. The specs are
2006 + M35/M45 19x8.5 +50mm
2006 Q45 Sport 19x8.5 +40mm
Danisiti 1
