rim help (been searching)
Rex
Car: None
Have you looked through the Fitment Thread?
lbkidsr20
Car: 240sx
i cant find out what the max backspacing is on a 89 240sx i want to put a 10" rim on the back without wide body quarter panels..... and if i cant fit that what is the biggest rim i can put without going past the stock quarter panels?
AZ89two4Tsx
Camber, camber, camber....
Gabes13
Car: rb20det s13
4"
simmode1
Car: Red '95 S14
If you want a 10 inch wheel in the rear with a minimum of fuss, you want to run a pretty high offset... like 17x10+40 for example. I think Broadfield ran 18x10+45 with square tires and no pull....
Also, check rimtuck.com
Gabes13
Car: rb20det s13
what he^ said.that's like a 3.5" of spacing and another .5" for fat tires would fit snug.do it.
lbkidsr20
Car: 240sx
thanks a lot guys ive looked on threads but i have no clue what there saying im trying to run a 15x10 so i should go with a 15x10 +45? what would be a good size tire to put on that so it dosent rub? ... and will this make it flush with the stock quarter panel ?
AZ89two4Tsx
How much power are you putting down? I HIGHLY doubt you'll ever need a 10" wide wheel. Please don't tell me you're bone stock.
Rex
Car: None
Are there any 15" performance tires made that will fit a 10" wide wheel?
lbkidsr20
Car: 240sx
not bone stock.... would you think a 8" is a better choice ? i want somthing big that will proform well i have about 300 to the wheels and only going up from there (not listing specifics bc i do street race)
lbkidsr20
Car: 240sx
most drag racing performance tire comes in a 15 mt m/h hoosier bf
koukicody
Car: 93 Mazda Miata
AFAIK you want to stay close to the factory offset if you want it in the fender, but 10" is pretty big so you might need to roll your fender. also depends on tire choice.
lbkidsr20
Car: 240sx
how much space in mm do i have from the stock offset to the fender? bc i dont wanto exceed the fender
