Rim for Winter
norwester44
Car: 2022 Nissan Pathfinder Platinum
HI-new here
Can anyone help me. I have a new 2022 Pathfinder and have a chance to buy some Infiniti rims. They are off 2019 Q50 and have stamped 19x8 1/2J with a 50 stamped and a SK84 also.
I assume the 50 is offset but not possitive as no ET after 50. I do not know what SK84 means.
I would appreciate any help I can get on this
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Infiniti equipped the 2019 Q50 3.0t Sport with a 245/40R19 tire.
Infiniti Q50 2019 Alloy wheel fitment guide
https://www.wheel-size.com/size/infiniti/q50/2019/
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Those Infiniti rims are a half inch wider than what was provided on the 2022 Pathfinder. All those variants, whether 18, 19, or 20 diameters, have an 8 inch width. An extra half inch shouldn't be a problem, and the 50mm offset is the same, but the SK84 may be a problem. The lug bolt pattern for both the '22 Pathfinder and '19 Q50, in the US market, is 5 x 114.3 (5 x 4.5"). I found a reference to the SK84, in the Czech Republic, as indicating the bolt pattern is 5 x 115. That's not much of a difference but it might make for a bad fit-up onto the hubs of your Pathfinder if this reference I found does mean the bolt-circle pattern is larger. I'm not sure if the extra 0.7mm would make any difference but I would look into that further to be sure before you purchase those rims. Here's the reference I found. >>> https://www.ekodily.cz/e-shop/1070442-c ... hlinikove/
JayArras
Car: 2013 Pathfinder SL Premium (traded in)
2023 Pathfinder Platinum AWD
mdmellott wrote:
Sat Jan 29, 2022 10:09 am
Great information, mdmellott! :dblthumb:
mdmellott
Note regarding Czech website reference: I noticed one of the images of the rim shown on this site has a partial Nissan part number on one of the rim spokes. When I enlarged the image, I can see 4GA3B, NISSAN, and J DOT. If I'm not mistaken the full part number would be D0C00-4GA3B, which is the rim that fits on a 2014-2015 Q50, according to Infiniti Parts Deal. >>> https://www.infinitipartsdeal.com/parts ... &filter=()
If you can see a part number on the rims you are looking at, like in that grimy image of the used rim on that Czech site, it could help you figure this out. When I looked up the wheel size for a 2015 Q50, I can see that it has a 5 x 114.3 bolt pattern. >>> https://www.wheel-size.com/size/infiniti/q50/2015/ I can't fathom why the rims from Eastern Europe would be any different than those used elsewhere. I don't like anomalies like this but I do enjoy a good puzzle. Thanks for letting me play.
norwester44
Thanks for the reply. I asked by e-mail if I could try one to fit, So far I'm waiting to hear back.
mdmellott
Although 5x115 is an actual bolt pattern size available for many different makes and models, I couldn't find even one verified Infiniti or Nissan use of that size. I did find further references to the SK84 In Poland and Ukraine that indicate this is simply a product code like a part number. Those other Eastern Europe sites I found indicated the bolt pattern as 5x114.3 so it's kind of odd that Czech site indicates that wheel as a 5x115 bolt pattern. The Czech site is probably wrong. Odds are, as I see it, those rims you are looking at are likely to fit-up just fine on your Pathfinder.
https://autobutik.com.ua/product/10012373090/
https://motorolo.pl/infiniti-felga-alum ... 50-1468788
