rim fitment?
freeagent6
will 20x10 +45 rims fit a 90-96 q45? tires are 255/35 zr20 93w
freeagent6
what about 19x8 +37 rims 225/35 tires?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Q45tech
The manufacturers MINIMUM LOAD INDEX is 95 or the ability to support 1521 pounds on the 90-96 Q45.
Tires must have enough safety factor to cover the weight transfer in turning or braking when up to 1/3 EXTRA weight is placed on specific tires.
The front is always the most critical unless so much luggage is in trunk to negate the 56/46 static load.
For example the Q sitting still has 1080 pounds on each front tire, add a driver and the LF gets ~half the divers weight depending on seat fore/aft position. That could be 1180 [with 200 lb driver].
During braking up to 300 extra pounds per tire gets added if full tank of gasoline more if back seat passengers or trunk item even more.
The other problem is the tire is rated at 1521 pounds under maximum inflation that would be 51 psi on modern tires.
When you undersiaze tires [load index] you greatly increase their wear rate and decrease their performance and safety.
But then anyone who would use a larger heavier than necessary wheel tire combo doesn't care about safety or wear rate.
Something in a 17 or 18".
NightRiderQ45
Car: 1998 Infiniti Q45
Q45tech wrote:The manufacturers MINIMUM LOAD INDEX is 95 or the ability to support 1521 pounds on the 90-96 Q45.
I agree with everything except what I put in bold. Again a load rating of 93...you are asking for trouble. My summer wheels on my Q are 255-35-20 97Y where I needed at least a 95.
Rex
Car: None
I think few (if any) have put 20's on a 90-96 Q45 and stayed around to tell NICO about it.
Most (Q45/G50 owners) have only moved up as 15", 16" & 17" tire options have diminished or disappeared. And even then, the "popular opinion" has been a conservative fitment. 17x8 to 18x9 in the mid 30's offset and non-stretched tires.
There's a few "fitment" threads with pics and specs if you search around enough.
freeagent6
thanks everybody. I will stay away from the 20s
