Rim dimension help
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
PIMPnifico
Car: 2008 Nissan Versa S
Hey guys and gals, I posted this in a semi-related thread, but it got minimal responses. I need some help before this weekend, so here goes.
I found some rims on craigs list that i really like and are a great price. only issue i have is the dimensions. they are 205/40/16 in front and 205/45/16 on the rear. will this be an issue? will they fit? are there ANY forseeable problems, or am i green to go? i trust the opinion of this forum and i will will make no action until ive recieved it. thanks to all.
07V84Z
Car: 2007 Versa~Silver, Hatch, 6Spd 1984 300ZX~White, 5Spd, N/A
you need to make sure that they are the correct lug pattern and offset. i dont believe the sizes you have there will be an issue, although the more common size for 16" wheels is around 195/60/16 i think. thats coming just from my own research in looking for wheels.
there are some other members that may have some more/better info but the basic thing you need to look at is lug pattern. i think the V lug pattern is 4/100mm or 4/110mm something like that.
remember, not ALL wheels will fit ALL cars. my suggestion, go to mrtire.com or something LIKE that, and enter in your car info, and look at the information for the wheels that they list for our cars. MrTire.com has a bunch, and they even have a program that you can customize to look JUST like your car, and put different types of wheels on it.
Versa Madness
Car: 2008 Nissan Versa S HB 6 spd
The Versa's wheel bolt pattern is 4X114.3mm also referred to 4X4.5in.
The tires that your are looking at are quite a bit shorter than the stock rolling diameter resulting in a lot of speedometer error. For a 16" rim, the proper size is either a 195/55-16 or 205/55-16.
07V84Z
4x114.3 i'll have to note that. thnaks
i was pretty close on the 16" size
but i guess PIMPnifico, your answer is no, you shouldn't use those, not with tire size 205/40 or 45 anyway. the wheels should be fine, but i'd say get some new, better fitting tires. as versa madness said, 195(205)/55/R16 would be the right ones.
PIMPnifico
awesome, thanks for the info guys. so the rims should be ok as long as they fit the 4x4.5 or 4x114.3 bolt pattern? and get new tires.
Modified by PIMPnifico at 12:42 PM 3/14/2008
Versa Madness
The only other question about the rims fitting would be the back spacing. If they came off of a front wheel drive vehicle then they should be fine. Off of a rear wheel drive car could be "dished out" to much to fit properly.
Another good fit in the 16" tire size would be a 215/50-16. Has the same EXACT tire height as stock (no speedo error) with a wider foot print for added grip.
gmader2001
Car: 2007 Nissan Versa
Does it make a huge difference if the rims are a different offset then what the car calls for? I too have some 16in rims but im not sure about the offset of them. Will it do anything to the car if its a different offset? also does the weight of them make a difference? because i noticed that they are alot heavier then the stock rims.thanks for any info
zilvia_brothers
Car: 1987 200sx 5-spd V6
i would like to know whats the lowest offset we could put on the versa...im trying to get rims with a lip and looks flush with the car and not having it sticking out like crazy
biggie
zilvia_brothers wrote:i would like to know whats the lowest offset we could put on the versa...im trying to get rims with a lip and looks flush with the car and not having it sticking out like crazy
Best bet is to do some measuring and calculations.
Here's a calculator:http://www.venommotorsports.co...r.asp
Just go out and measure the differences on your car.
DejaWiz
Car: 05 Honda Odyssey EX-L
See sig for details.
Versa Madness wrote:Another good fit in the 16" tire size would be a 215/50-16. Has the same EXACT tire height as stock (no speedo error) with a wider foot print for added grip.
215/60R16's will cause a speed reading error of about -4MPH (traveling at 64 when the speedometer reads 60).
185/65R15 = 24.5in diam215/60R16 = 26.2in diam
That's a heck of a difference. 215/50R16 will retain the stock diameter of exactly 24.5in.
Return to “Versa Technical Discussions”
