gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sat Jun 02, 2007 7:37 am
If you are intent on keeping shox/struts, a +35 should clear. What width and offset are your 16"s ? Normally I would have you do your own math, but I will be playing with tire sizes this weekend anyway, so I will help.Secondly I would advise against going with 18" wheels. You would be pushing it at 17" but if this is what you have your mind set to, so be it. As far as the spring perch, try and keep your tire diameter at about 25". Something in a 225/40 for the front and a 255/35 rear.
