right turn signal turns off when braking
the-chifrog
For some odd reason when ever I brake with my right turn signal is on, the signal gets canceled. Also I find that when ever I brake the right turn signal lights up dimly on the dashboard console. so is there anyone who has the solution. could it be my tcm because i had it fix a while back ago.
navysnail
wiring is crossed somewere, check the wiring under the dash
Dattebayo
did you get a new TCU or was it a used one?
the-chifrog
I just jumped the burnt circuit by using a wire and some solder.
but it could be the tcu/tcm. what is the purpose of the tcu/tcm I know it affects the lights.
