Are you trying to say your parking lights are stuck on?!? Do you have an aftermarket alarm in your car??? I had a problem with my Talon where sometimes the alarm would get all messed up and cause the parking lights to stay on after flashing. I could never figure it out so I just stopped using it all together. However, this could be totally useless information if you don't have oneaceof07 wrote:alright there's yet another twist in the puzzle! the signal is also stuck in the mode in between the headlights being on and being completely off. this bit of electrical problems are kicking my @ss.
when you turn the lights or running lights on , you are making a certain wire hot which is rubbing against the green/yellow wire. There is not supposed to be any connectin between headlights and blinkers or the headlights and hazard lights. There is however supposed to be a connection betweeen blinkers and the hazard light.aceof07 wrote:alright there's yet another twist in the puzzle! the signal is also stuck in the mode in between the headlights being on and being completely off. this bit of electrical problems are kicking my @ss.
trace the green/yellow wire to instrument cluster to see if anything looks wrong. wiggle the wires in instrument cluster to see what affect it has on your blinkers when lights are on.aceof07 wrote:i have a one question about this. is it possible for something in the gauge cluster to be causing this?
aceof07 wrote:right now i feel very stupid, jeromeS13 was right all along! i made a dumb *** mistake and chose the wrong bulbs. i feel so stupid for wasting ur time but thanks for all the help!
