Yup...ChuckNC wrote:You checked the brake lights as well as the running lights?
Alrighty, i'll check that out and see how it goes. Thanks...s13rb25det wrote:I had that happen on my 91 it was the wiring on the front turn signal one of the three wires were loose. check them.
Ha Ha Ha....... yeah dude, that joke has been dead.Skeeg wrote:need new blinker fluid im guessing.
I dunno? How do you know if a relay is bad?bware113 wrote:are your relays bad at all?
Yeah i changed them all, including the LED's interior lights haha...ze12o wrote:i concur
But seriously you changed all of the bulbs? or did you just check if the filament was broken?
I know where they are located, but how to you know if a relay is bad? I'll check if there is a loose wire tomarrow. Thanks!bware113 wrote:Your relays should be located in your fusebox. Do check your connections too it is very possible they could be loose.
i didn't see any when i changed the bulbs...silpena wrote:did u check for corrosion at the connectors?
Well it was a loose wire on the right turn signal light. Both turn signals work fine now! Thanks for all your help!EnjoiNismo wrote:I have the same problem, let me know.
