I have an issue on my Altima (coupe 2008) with BOSE,
The speakers on the Right side sound lower than the Left side when the Balance RL is 0.
I tried with the speaker test (Chanel Check Diagnostics)* and all the Right side still sound lower
The music with stereo features sounds rare and uncomfortable, some songs with low level voice sound, other songs with low volumen on the the guitars for example...
*OPERATION PROCEDURE
1. Turn ignition switch to the ACC position.
2. Turn the audio unit off.
3. While pressing the “AUDIO” button, turn the volume control dial
clockwise or counterclockwise 30 clicks or more. When the self diagnosis
mode is started, a short beep will be heard.
Initially, all display segments will be illuminated.
Channel Check Diagnostics
When all segments are illuminated, press the “TUNE” up switch to
enter channel check diagnostics. The self-diagnostic function will
then send a tone to each channel (FL, RL, RR, FR) for 1 second.
Someone have this issue too? and how can I fix it?
Thank you!
This is my car btw:
