right side headlight wont turn on!
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
just installed new sr20 gauge cluster although i know its not the problem my right side headlight and fog light will not turn on checked the fuse its good both bulds are also braand new an the relay is good to anyone have any idea what it could be?? could it be water on the headlight harness?
costa_rican13
Car: 1993 s13 coupe
or maybe you messed up the wiring put the the headlight cam back on. idk. check the motor plug and grounds.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
isnt the sr gauge cluster direct plug and play?
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
basically they go up but just the right light wont turn on on high or low but its a new buld left side works perfect though
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok so no power is coming to the headlight so im gonna trace it back and see where it ends
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
One of your connectors probably got loose. Reseat them all.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
could it also be the switch on the column?
Lobo240sx
Possibly but not likely to be. Is the connector that goes into the headlight corroded?
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
nope im not getting any power through the harness either so i think tomorrow ill try and check the switch and go from there but bulds are good for sure
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok no go combination switch is fine but still no go are each of the headlights on different relays?
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
basically i cleaned it like i was told but still not working :/
240sxAli4Life
Car: 1990 S13 Hatch SOHC... SOLD :(
1993 S13 Hatch DOHC!! Super Sexy!!
Huh.... weird!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Could be the headlamp timer. It activates a relay (headlamp retract) that opens the lighting circuit while the pop up motor is working. check the retract relay for that side to see if the timer is keeping it active. A test light across the solenoid contacts will tell you that. if it lights up, you got a problem. Also, try another relay in that socket The relay could have failed in a closed position.
costa_rican13
Car: 1993 s13 coupe
to see if the relay is the problem, just unplug the motors. and turn on. also check your little fuse box by the coolant resevoir.
Hijacker
'94 F-150
Unplugging the motors only tests the headlamp timer. If a relay is stuck/burnt out, the unplug motor trick won't work.
Also, to properly test the timer, I would take a test light to the motors as well and check for a constant light from the Br/W wire to a good ground. If that one is always on, the timer is bad. If you get a positive test light over the relay solenoid, the motor has an issue
john_93 vert
Car: 1993 Nissan 240SX S13 vert
Look at the cluster with the headlights on (in your case L. side only) now turn on the high beams - check for the hb indicator light in the cluster- if it is NOT on then the issue is likely your combination switch- if you have a wiring schematic you can see how the hb indicator light is connected to the right side headlight-- We have had this issue happen twice in our fleet of S13s -- replaced the combination switch - problem fixed
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
well i checked the relays they are good checked the switch again and tested it its burnt... so gotta buy a new switch :/
