Right rear speed sensor, but I don't think so
carlosinseattle
Car: 94 Q45a 91 Q45 Base SOLD
Hello;
I have a 94 Q45a which I bought around 18 months ago. It was a project car from the beginning, and I'm finally starting to make some progress. the car is equipped with the TCS system, which is what's causing my problem. I'm getting code 7 from the TCS CU. I can't understand why. I've Ohm checked the speed sensor and it checks out fine. I've checked the connection between the harness and the TCU CU and all is well there too.
Her'e what happens. When I first start the car it's fine, but after driving for about 30 seconds the ABS, Slip, and TCS off lights all light up at the same time. I've checked the rotor for cracks or deformities and it looks even better than the one on the rear left.
This problem all began about a year ago when I was stuck in some snow. I was spinning the trires trying to melt the snow directly under the rear end. The TCS was kicking in, so after a few tries I hit the switch to turn it off. The next day when I drove the car is when I began having the problem.
Can anyone help me figuree out what to do next? The sensors are expensive, and pretty difficult time consuming to replace, so I'm trying to eliminate any other potential problems. And I think the sensor is fine because when I first start the car and accelerate hard I can cause the rear wheels to lose traction, and the TCS system kicks in flawlessly to stop wheel spin.
Modified by carlosinseattle at 5:18 PM 6/1/2008
qship96
Car: 1996 Infiniti Q45
Check battery voltage and alternator output.
carlosinseattle
I checked battery voltage both with the vehicle running 14.18 volts, and with the motor off 12.01. I replaced the alternator a year ago too, and, had it tested before installation to be sure it was good. I also replaced the battery around 6 months ago.
Anything else I should check????
Modified by carlosinseattle at 6:32 PM 6/1/2008
carlosinseattle
Moderatoe.
I posted this topic in the q456 section because I didn't get any response here. Feel free to dele this on. Not trying to double post, j ust hoping for help.
