Zion8561 »
https://forums.nicoclub.com/zion8561-u28751.html
Wed Apr 19, 2006 10:57 am
It may be your switch. I had some funky headlight problems when I got my car, and it ended up just being the switch. The contacts get worn out, there is also a built in relay on the switch.
My gauge lights would barely light up, but after I replaced the switch they worked great. I did not have any issues with fuses blowing though, so it could be chaffed wires. If it is not the switch itself it is probably the wires right near the switch.
If you know someone that lives close you can swap thier switch to see if that is the problem before you spend $35.
