Right front fog light out
the panther
Car: lincoln
My right fog light is out is it hard to replace ? and what bulb do i BUY>>THaNKS
fueler
Car: 2 Nissan's
2 BMW's
So many different foglights on pathfinders and QX4's.... it really depends on the year, make, and model.
Let me know!
KyooX4
Car: 2001 Infiniti QX4 4wd
No, it's not difficult to replace fog light bulbs. Just need a screwdriver and/or socket wrench. It's pretty self explanatory if you get in there and look at it. You didn't mention what model and year your vehicle is, so I can't really help you in depth.
As for which bulb you need:http://www.sylvania.com/Consum...Guide/
the panther
Car: lincoln
I should have said 2001 Qx4
KyooX4
Then that would be an h3- 55 watt bulb.
On the assembly, there should be two screws. Unscrew them and the 'grill' beside the fog light will come off. Then there will be a bolt that secures the fog light on its respective side. The other side of the fog light is secured by just a tab. Remove the bolt and pull the assembly out. On the back of the assembly, twist off the cap that has the wiring harness going into it.There will be a pin that secures the bulb in place. Push down on that and to the side (like a safety pin). This will be the hardest part if you have average or larger sized fingers, as the space is tight.Take the bulb out and remove its wire from the socket in the cap.
Reverse for installation.
the panther
Car: lincoln
neat - thanks for that; that will make things easier!!!!!!!
