right and left turn drifting
Nissan dominates the drift scene - Always has, always will.
epoch707
Whenever I pull the old e-brake to drift my left turn drifts are always better than my rights. I try to practice both ways but it looks distinctly better whenever I drift to my left. Does anyone have similar observations? Is it because of how the open differential affects only one wheel?
Matej
That's the case with almost everyone, practice drifting to the right more, and soon it will feel the same both ways. It's mainly because of the side we sit on and the side of the road we drive on, in Japan they have the same problem with drifting to the left.
And don't use the e-brake to drift.
epoch707
yeah I know, Im starting to initiate through the braking drift but the ebrake is much easier
kireiS14
Car: '95 nissan s14
that's what happened to me (the whole left turns are easier then right)i never use ebrake; i don't even know how to yet... i clutch kicked the first few times i tried to drift, but then one day I discovered how to power over at the track. It's so much easier for me, plus I don't feel like i'm killing my clutch anymore.
keioffice
Car: 1998 240sx SE
its probobly because of your open diff, both wheels will lock up going left but not right. you should still be able to drift going to the right, but you will slow way down. weld your diff or get a 2 way
Joe
epoch707 wrote:yeah I know, Im starting to initiate through the braking drift but the ebrake is much easier
lol if you are having problems drifting to 1 direction, braking drifting is NOT for you yet
use the clutch kick. it works the best.
neverlift
yeah c/k is very effective but IMHO shiftlock FTMFW! I know I know but its insta drift.... *** out tire(s) roasting away already. bliss
Joe
too bad you loose entry speed when you do it.
thats why clutch kick > all unless you have a hydraulic ebrake setup.
neverlift
I'm not doing high enough speeds to worry about dropping a few mph at the moment,but I can honestly say the c/k method slows me down too,yeah its less now I put thought into it....
DrftS13
Car: '91 Nissan 240SX (silvia coupe)
just practice more right drifts. it goes the same for me to. after awhile it will be come just as natural as your left drifts!
sx_hatch
Car: 90 240sx coupe
weld the diff and use the clutch kick method its more prodictable when you have a open diff it kicks posse for one second and sometimes it kicks one legger and thats confusing
Return to “Nissan Drift Forum”
