Q45tech wrote:the handling is definitely worth it ??
Just like big wheel are for looks, inexpensive [without total redesign]lowering is primarily for looks.
The handling gains are so minute in improved g forces [to me a 1-2% IMPROVEMENT IS MINISCULE].
Well, numbers don't lie.
The Eibachs are stiffer, as is KYB the shock rate on the FY33. Lowering seems minmal, maybe an inch F&R. The main thing is it is not so tippy and permits delving deeper into the sideways G loads the PS2 can produce with less anxiety. Obviously, the tires don't produce any greater G forces.
But the ride is definitely more jiggly, with no float, and tightly controlled rebound. Not harsh, but not Buick like luxury either. Not a bad trade off. And I don't have to approach driveways and speed bumps at an angle, much to my relief.
One interesting comment that Duy made to me is he thought the Teins were about the same spring rate as OEM. With reduced suspension travel, this would not be good, and he had to approach driveways and road surface obstacles at an angle or bottom out. My grossly inaccurate buttometer would guess the Eibachs are about 20% stiffer than OEM.
Anyway, when I decide to firm up my G50, I will get springs made 20% stiffer and maintain stock ride height and suspension geometry. Even if the blues wear faster, so be it.
It's dynamic performance, not static looks which matters to me. I don't drive on billiard tables but real world roads, many under construction.
