Whoa! Lots of pessimistic, middle-aged opinions floatin' around here.
Woodmister, "overkill" is a vast understatement in describing 20's on a Q. Forget about ride comfort, you'll lose your kidneys and the rest of your major organs everytime you encounter a speedbump. The cost of 20" rims is very expensive, at least a couple thousand for a barely decent set and an arm and a leg for adequate tires.
It's like all the girls say, size doesn't matter, it's all about style.
Slick rims will look good regardless if they're 16's or 18's. First things first though, make sure your Q is in tiptop shape before you do any extraneous mods. I'm doing a little research on some factory 18x9.5 Cobra wheels. I'll be addressing the stock brakes at the same time.
BTW, welcome to the club!
