Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Nov 29, 2002 10:48 am
I'm sure you haven't tried everything: as the shock towers can bend inwards, the third link can bend, the lower traverse arm rubber can wear.If the car has ever hit a curb or been in any kind of accident, a tiny amount of non standard [LESS THAN 1/8-1/4"] total error is enough to add 1.0 degrees of negative camber.
You will find hundreds of side to side and angular measurements in the shop manual. The section BF "Body Aligment" !
But easiest to measure a springs free length. To start! Then the distance between the strut bolt holes across the engine. Then replace the third link if these are ok.
The 90 Q is 26.97" with the correct tire so a 1/2" lower would be roughly 0.4 degrees extra camber.Don't have a 94 book handy to check why the wheel arch height is higher.
