greencar wrote:The basics:
92 240sx with stock internal ka24de, 16,000 on rebuilt motorE-Fans with DIF controllerCX Racing Aftermarket radiatorAutometer Temp Gauge
The car has a new Nissan OEM thermostat, a relatively new H20 pump, and hoses.
I have bled this car many times when it was bone stock.. my radiator clutch fan popped the radiator and this is what warranted the new set-up i have now.
For the life of me, it would warm up but as soon as I drive it, the temp would shoot up instantly.
I decided to drill a hole in the thermostat (7/16) it ran fine after that but would only stay in the 120 degree range.
I put in a new thermostat with a 7/32 hole and it is now randomly overheating again..
I can drive around town, but if cruise at a constant speed, or I get on the freeway the temps start rising. If i turn on the heat.. it starts to go down. But sometimes with the heat on the temps dont lower.
I believe that the aftermarket cooling set-up is too efficient. the cold air in front of the thermostat is too extreme for the hot water behind it and it will not open up. Am I crazy here?
Any suggestions Niconaughts?
Why would you drill a hole in the thermostat????GO BUY a factory nissan one, your new thermostat is probably defective.
A water pocket will not cause your car to overheat. A water pocked from not bleeding correctly will make your water temp sensor jiggle and vibrate.
There are a few factors why your car is overheating.
1. The CX radiator is defective. These China radiators have manufacturing defects in them. Common with Megans, Mishimoto, CX, XS, Circuit sport, griffin, etc.
2. Your thermostat has an issue. Your car usually overheats because the water in the block can't exit and the sensor on the block picks this up, and needle rises. Coolant stays in engine at optimum warm operating temperature, once it's is too hot, the thermostat will open and water circulates. So overheating usually has to deal with thermostat. (Maybe you could have installed it backwards?)
Those are the ony two major defects I would think of because 9/10 times, when I change to a new OEM Factory Nissan thermostat, it fixes the problem. At $15-20 bucks. If you changed it recently, make sure you didn't get RTV silicon all over the thermostat.
