ridding rust and prevention
babowc
Car: 240sx
the 240 i just bought had some rust spots inside the hatch when i gutted it.. i went over to it and just used rust-oleum metallic silver spray paint.. but i dont exactly know why i did that..
anyways, how can i get rid of rust and prevent it from rusting back? any help would be nice, i read in some posts (after searching) that..you sand the area down of any rust, rust protector (whats this?), bondo (?), primer(?), then.. paint i believe it said.. but..
id ont know what half of those things are.. i only know them by their names and sanding wont sand through the metal would it?
thanks!
XingYu
Car: 1993 Nissan 240SX
how bad the rust? You shouldn't need to bondo it if the rust is just light layer and nothing serious. Theres something you could try called Rust Bullet. You basically just sand and spray. It tells you everything you need to know on the website. A search should turn it up. Ive heard lots of good things about it, but its a bit expensive and you need a spray gun.
JimmyMethod
Car: 97' 240SX SE
Wash your car on a regular basis. Some people seem to think that every couple weeks is enough.Once a week.
babowc
Car: 240sx
well, its onyl a couple surface rusts inside the trunk/hatch and where the wing used to be.. 10 holes.. need to patch these up before it rains!
Axel Grungy
Car: 2001 G20 5spd
just to be off topic, babowc why do you have a mini cooper in your sig, with shift_.....
im not beitching, i just thought id point it out lol
XingYu
so its the spoiler holes that have the rust right? for now u should use electric tape or duct tape to cover it up for now. Youll probably have to sand down the rust and fill the holes in with bondo. I think your supposed to use metal shards to fill them up for better strength. Then probably prime it and paint.
babowc
Car: 240sx
lol it looked exactly like my shifter.. o_O its a minicooper? haha you have keen vision!
duct tape eh.. i tried sanding it.. but i kinda sanded the paint off,
lrb_2000
Car: '91 Nissan KA-T hatch
I put in nylon hole plugs, with silicone around the inside of em.. lol.. cost me like $3.
