Richard says his SR does 62.1mph time is 3.7 sec
cuzan0
This guy Richard from Venutra says his sr20det does 62.1mph in 3.7sec http://users.adelphia.net/~projectd/main.html click on richards tuning....doesnt a ferrari do 60mph in 3sec??? what a boolsh!tter lol
Dori Dori
Car: Cars of course
Chances are he measured that time using some sort of gtech type device and they can be pretty inaccurate if not calibrated correctly (weights are very important).
f150intally
G-TECH said my car did it in 4.8 seconds. That ofcourse with drag radials. Of course I knew the exact weight of my car.
Dori Dori
Car: Cars of course
Wait, now that I think about it...aren't the hp and tq readings the only ones reliant on weight?
Def
Car: Cars, Engineering Stuffs
Yep, 0-60 and 1320 time are solely calculated with the internal accelerometer of the G-Tech. If they are calibrated before you start by zeroing out the reading, then they are fairly accurate.
Soft suspensions and hard shifts tend to throw the accuracy off by using a small amount of gravity to fool the G-Tech into thinking you're accelerating faster than you are at times.
f150intally
Dori Dori wrote:Wait, now that I think about it...aren't the hp and tq readings the only ones reliant on weight?
yes. this was my understanding. only calculated values derived from the time based measurements rely on weight.
