duty780 »
https://forums.nicoclub.com/duty780-u61802.html
Fri Apr 06, 2007 5:37 am
I have a 90" 240sx coupe, with a swapped 93" ka24de. the engine only has around 80 thousand miles. i Just recently did the timing chain, and the timing is at 20 degrees just to run safe. I have a cold air intake that goes all the way outside to where the bumper is, plus headers, and 2 1/4 straight pipe back. All this was great. My car, before i installed my air to fuel ratio gauge, idled from 650-850 rpm very slightly, never knew why until now. Now that i have the gauge it runs very rich at wide open throttle, and ok i guess at normal speeds. the problem is that after a while, about 10-15 minutes of driving, it goes completly lean, it actually disappears out of the gauge. i know is not the gauge reading it wrong because the car feels like crap and starts idleing very severly,i have to keep my a/c on so the rpm could chill out . i am not over heating because i have 2 electric fans running constantly. Nooooooooo is not my fuel pump, i tested it and i was running at 40-41 pounds.what in the world could it be ????????? any help would be greatly appreciated.
p.s once it runs lean, if i speed up around 60 70 mph it will start running rich again, until i start to slow down in which then it will slowly begin running completely lean again.
