the_momo »
https://forums.nicoclub.com/the-momo-u29599.html
Mon Nov 27, 2006 3:21 pm
as it states.
rb20 in s14. i have stock injectors for an rb20 (thanks rbspitfire) in my automobile...my plx says its at 14.7 when i first start it then it gradually drops and idles rougher and rougher the richer it gets. does it without any input from me (it makes its own decisions apparently). itll go to below 10:1 and it just says rich.
what i have.rb20. lots of prior hacking. the car was originally run without the iacv, the throttle was opened a little. it idled at 11.7:1 with 550cc rx7 injectors and a blow through gm maf but it ran.
it currently has a stock blue label (cant remember number) maf (its actually not from an rb20, but i cross referenced the numbers and the one i have is the same pn.)maf is draw through. stock injectors and stock ecu. the car starts and idles the same way every time. no trouble starting and eventually descends into being rich. wouldnt it be nice if it were that easy.
i fixed all of the wiring that was modified back to factory. the wideband o2 sensor's output to factory ecu is usedit has one of the large plenum intakes (prob ebay junk, came on the car) with only one vacuum port. it does not have from what i see an aac valve/sensor, the one with the 2 wire brown plug.
things that werent used on prior setupcoolant temp sensoriacvaac
there is no aac, the iacv was not even on the motor, and the coolant temp sensor was in the center console. where does the cts go specifcally? (i have it in a water line as of know but i am sure thats not where it goes (i have metal water lines, yeah, not my work, dumb idea, gonna change soon)where could i get an aac cause im sure i need one.i have good vacuum(18-20) but could having the iacv in the same line as other vacuum lines make a difference? ive done other cars like that and it wasnt an issue.(iacv goes charge pipe-iacv-intake manifold)and lastly does anyone have any other ideas i can try to get it working?
so thanks for reading i know this is a reallllly long post but i am giving as much info as i can. i know some of you are wanting to me but this is my first rb and i bought the car swapped and modified. my mistake i know. most of what i have found for troubleshooting my issues has gotten me to where i am, better than i started but not yet finished.i get no codes other than the uncertain girlfriend code 55 "oh everything is all right....liar. any and all input is greatly appreciated, and thanks a bunch in advance. sorry again for the mega post
Modified by the_momo at 8:33 PM 11/27/2006
