Bobbymudd »
https://forums.nicoclub.com/bobbymudd-u273602.html
Tue Aug 13, 2019 9:26 am
Hey Guys, have another issue that im hoping the combined knowledge of the forum can help me figure out.
Have a 91 TT 5spd that ive had for about 3 years now. It has 90,000 miles and ive done all the preventative maintenance, 120k Kit, spark plug, New OEM injectors, new OEM fan and fan clutch, new knock sensor in OEM location, etc. then I started to do some performance stuff, downpipes, testpipes, catback, an upgraded RPS clutch, an intake, ETC. So in my mind the next step was to do some light tuning. I bought a used ECU off a forum It was for a 1990, TT, 5spd Cali emissions. I live in Missouri but was told that when i replace the Eprom chip in that ECU it would wipe out the Cali emissions portion and i would be all good. Then Bought an upgraded chip off a forum that was exactly what i was looking for. 5spd, single intake, stock injectors, etc and it was supposed to be safe up to 15 psi. It was also from a reputable tuner, Harry at Z tuner. I also called and talked to harry to confirm the details of the chip. Then i went out and bought the 12-13 psi boost jets from concept Z because i wanted to be safe and make sure i avoided detonation. So when i had it at the shop for some smaller stuff they agreed they would do everything besides socket my ECU and install it. So i agreed id have that done elsewhere and id just drive the car easily since it would have the boost jets installed on a stock tune. Got the computer done and installed it and had some issues. While at the shop i had them install an AEM wideband. On my stock tune at idle the AF is right in the middle at like 13-14. When i installed the new computer with the tune it started but ran kinda rough. when i looked at the AEM the AF was maxed out rich at 22. So i put my original computer back in an have just been driving it easily. So any suggestions for testing? i dont know a ton about tuning but from what i understand the Eprom chip controls the fuel map so the problem is likely with the chip and not the ECU? Any Ideas would be really helpful. Also tell me if this is to be expected. This is my first experience with tuning so i didn't know what to expect. Thanks again guys.
