Rial Restoration build
alphapig
Car: Nissan Altima Coupe S 2.5
So I got this set of old school Rial Imola 2 piece wheels in 5x114.3, which is pretty rare (German wheels)
They are 18x8 +35 and 18x9 +22
They were in sorry shape when I got them:
Lips on the fronts had bends:
Peeling, stained clear coat :eek:
More to come!
alphapig
Poor wheels have been neglected
Check out the years accumulation of dirt/dust!
Got them to look like this
Next I took the wheels apart. 25 bolts, size m7-1. Used a 12 point 8mm socket for the head of the bolts.
Rear lip
:eek:
alphapig
Trial fit I did:
Yummy poke
Refinishing the lips:
Used liquid paint stripper to get the clearcoat off.
Then lots of sanding, grit depending on the damage. I used 120, 220, 400, 600, 1000, 2000.
Sanded by hand. Have to use one-directional and long strokes.
This is after 220, huge difference already
After more sanding:
Then rubbing compound and polish. I did everything by hand
Sprayed about 2 coats of clear coat:
alphapig
Decided to properly polish the lips
Not going to clear coat it
Weapons: dremel, lots of polishing bobs, mothers and white diamond polish
Here's how the front turned out:
Any comments or questions??
alphapig
Front lips finished
ShinHed
Car: 1998 S14, 1993 S13 coupe, 1986 720
How'd you repair the fronts?
BTW,
POR-15 has an awesome polished aluminum clear coat if you change your mind.
alphapig
I had them repaired at Wheel Techniques in Santa Clara, $250 for both lips without any additional work. Turned out great, the machining process they use also got rid of all bothersome deep curb rash.
I trust POR-15 a lot, I'll need to check that out.
However, the lips are polished steel, I believe
