RHD swap questions.
jjisguilty
Car: Zenki S14
I'm not planning on swapping soon, but i just wanted to know this. What can you do about the trunk/gas cap lever and how do you relocate it. Also, is it difficult to find center consoles and e brakes to fit also? Any info is helpful. Thanks
jjisguilty
Car: Zenki S14
Also is there any other RHD small things that arent obvious?
mirra32
if you don't have a welder don't even try....it'll probaly be a pain...if you have a welder use it...bend some metal make things fit...i just did the rhd and will be facing these problems when i start relocating these things...its not to hard just use your imagination
