akwikz »
https://forums.nicoclub.com/akwikz-u44134.html
Fri Aug 21, 2009 10:32 am
I see a few issues with your plan. First off, the body harness for a 510 is all of about 10 wires. It may look daunting with it all ripped out, but you'd be best off just buying a painless wiring kit (or the less expensive knock off) at about $150 and custom wire the car. On a 510, all you need for the body is headlights, taillights, and turn signals.
The SR20 harness is nearly self supported, as are all Nissan engine control systems. You can wire that in to the ignition or simply into a switch of it's own. No need to mess with the body harness from a car that had cruise control, computer controlled A/C, HICAS, etc.
Now, the RHD part. The short answer; no. I have converted a 510 to RHD, with actual RHD 510 parts. The components from the S13 will not work, at least not easily. The 510 uses ricirculating ball steering. The S13 is rack and pinion. The pedal box on a RHD 510 is different than a LHD one and again very different from an S13.
Anyhow, these are a few things you will need to consider.
Brian
