RH wheels and Z brake clearance
Touring240
yes I searched
anyone know if 17x7 RH Z5000 +40mm will clear NA 300zx front brakes?s13 with kyb agx/sportlines
I know the c3's and c2s won't clear due to the spoke design. z5000 look like they may clear.
thanks
SmithSR
Car: 240sx
Touring240,
+40 sounds too high. Don't the Z cars use closer to a +10 ??
Call Dazz Motorsport, the company who makes RacingHart, and find a salesperson who can answer your question. 626-962-0033
You may want to act as though you are looking into this problem for a customer, as they don't deal well with the common guy looking for wheels. Good luck.
-Phil
Touring240
thank you for your advice I'll give htem a call
Exar-Kun
Car: 2005 350Z
they might also go "you won't know until you test fit them"..
because unfortunately, you really dont :(
spoke design has a lot to do with Brake clearance.-chet
