It has some front end collision damage and I hope this is the reason it went to salvage. The odometer reads 22,565 miles. However there was a pile of gaskets on the floor board (now on seat), so maybe some one was planning to do some work on it and maybe it needs it. I need to clean it up. Check the motor a bit by pulling the head cover and oil pan? The wiring harness looks in tact except for the engine compartment and ignition switch. I bet some one chopped it up and added wires getting around not having a key. Anyway, after some cleanup my first step will be to try and figure out the wiring mess in the engine compartment so I can get spark and ignition. Any direction, suggestions, etc would be appreciated. I'm new to this game, so... RIch
Protocol question. is photobucket-copy into post ok (I kinda got this figured out) or is it preferable to link to flickr as other members do? Is text properly above or below picture?
weird hole left front transmission tunnel
Notice the broken windshield, also the irregular indicator lights
