CINNALOCKS »
https://forums.nicoclub.com/cinnalocks-u19492.html
Fri Jan 12, 2007 10:02 am
My central controls work except for the right front door. The door will not unlock or lock, nor can I control the passenger window through the central controls. The window will work by using the passenger controls even without the key in the ignition,it will go up and down . I have been told it may be the power window amplifier... but I hesitate to replace if this is not the issue. Any suggestions.
