pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Fri Mar 11, 2005 11:56 am
Hi,
To wire your knock sensor you need to a shielded wire similar to an RCA audio wire or cable tv wire idea etc.., Look at the engine harness wire plug that goes behind the battery and the passenger fender, it should have two wires one is white wire (signal) and black wire (shielded ground), if you have the plug for the knock sensor, just hook the white wire of the knock sensor plug to the white wire on the plug behind the battery and the black wire of the knock sensor to the black wire on the plug behind your battery.
The white and black wires are accross from each other on the plug behind the battery.
Hope this info helps.
Good luck,PULSAR GTRRafi
