mrodrig2 »
https://forums.nicoclub.com/mrodrig2-u106864.html
Mon Mar 16, 2009 5:37 am
Remove the plug from the existing harness or just disconnect the existing plug and buy a spare pigtail. Plug the LED into the pigtail. Run wire from the pigtail to a power and ground of your choice and of course whatever switch you are using. For the power, tap into something that's always on so you can use the switch to turn on the lights whenever. I think its that simple.
