rewiring car system
Post all your Nissan electronics, car audio and stereo questions here!
panther21
Car: 1997 J30
Is there any way i could use my factory wire to rewire my system WITHOUT using the factory amps?
qsiguy
Car: 1994 Infiniti Q45 Turbo
Bose system I'm assuming? If you can pair up the wires at the speaker end and the radio end you can use them as speaker wires. They are just a little small and you might not have enough wires to do 4 pairs.
carcrazyguy
Car: 89 240SX SE, 94 300ZX, 94 Q45
Yes, you will need 4 amp bypass harnesses. The ones seen below are for 89-90 (production date) Bose equipped Q45, 300ZX, Maxima...yours may look a little different likely having blue harnesses which are typical for 91 on. However I am not 100% sure about an I30.
panther21
Car: 1997 J30
do you know where i could find some of those??
carcrazyguy
panther21 wrote:do you know where i could find some of those??
I sell kits for the older stuff (300ZX, 90-96 Infinti). However, I am not 100% sure of the harness you will have on a 97 J30. If you have a door panel off and can see what the harnesses that patch into the Bose enclosures, I can see if any of the ones I sell are the same.Actually I forget...you can look in your trunk at the rear speakers...see if you have a 4 pin blue or white harness that plugs into the rear speaker / amp assemblies.
