Rewire assist:Speed sensor input
SxMachine
Car: Im on a horse
Wiring up my sr for swap and i discovered that the speed sensor input wire is cut at the consult AND the ecu and does not continue through the rest of the harness. Should it be completely gone? I'm looking at my ka(e) harness and the wire continues throughout the loom from both the consult and ecu. Obviously the previous owner tried a speed gov cut but the wire is completely gone. Big deal or not?
Modified by SxMachine at 12:44 AM 5/19/2009
SxMachine
Car: Im on a horse
...and if it is a big deal should I wire it throughout the loom(in case I decide to use it). I just dont know where it ends. Any assist would be appreciated
tdown
The speed sensor has two wires that run the the speedometer (yellow black and yellow blue). From the speedometer the yellow/green wire runs through the dash and down to the ECU. So the speedometer will work without that wire.
SxMachine
Car: Im on a horse
Thanx thats wut I needed
