revolutionz_s13's KA24DE-T coupe build
revolutionz_s13
Car: '92 240sx coupe KA-T
'95 240sx SR20
So I decided to post my build thread up on here for more suggestions from the community as I progress along on my build, here is where I am at so far:
Well, I finally started ordering parts for my car again. Its been sitting in storage for about the last 2 years, due to a checkbook drought :? , but now I have a new place with a heated garage and some decent income again. I'm going for at least 450whp on e85, would like to see 500whp, but that might be a stretch. I still need a whole grip of parts (and money) , but I think I have a pretty good start on it. On to the parts list/pics....
Powertrain
Wiseco Pistons, 9.0 comp
Eagle Rods
ACL bearings
ARP Main Studs
ARP head studs
JWT s1 camshafts
Koyo Radiator
Garrett GT3076R turbo, .82 a/r
Tanabe Concept G catback
Nismo motor mounts and trans mount
centerforce dual friction clutch
nismo 2way lsd
c's short shifter
dual 10" electric fans
Walbro fuel pump
JWT Cam Gears
Xcessive Windage Tray w/ crank scraper
ATI super damper crank pulley
Xcessive Intake Mani w/q45 flange and SS throttle cable bracket
Xcessive lowering motor mount brackets
Cometic Head Gasket
JGS turbo mani and oil lines
AEM Fuel Rail
BC springs and retainers
supertech valve seals
BC SS Valves, Std size
Suspension:
JIC flt-a2 coilovers
cusco front tie bar
Suspension Tech. F&R sway bars
spl tension rods w/ brake cooling air deflectors
spl ruca
sentra se-r brembo calipers
r32 skyline rear calipers (might sell and get ksports front and rear instead)
JIC front and rear strut bars
autopower race roll bar
tein tie rods
TechnoToyTuning subframe collars
Energy suspension poly bushings in the rest of the arms
Exterior
SSR Professor MS1 wheels 17x9,17x10 +24, 1/4" spacers on fronts
(Yes, they are 4 lug!)
front 255/40, rear 275/40
ARP wheel studs
Bomex front lip
silvia sideskirts
What I started with, about 5 years ago:
Pulling old motor, tearing it down to send the block off, sanding it down for paint:
Block back from machine shop, car back from first attempt at paint, put on suspension parts, test fit wheels:
Bunch of the parts I have sitting in my bedroom, waiting to be bolted to something...(no longer have the emanage, sold it to get aem ems)
Parts I'm planning on collecting over the winter:
Vibrant intercooler
Synapse Synchronic WG and BOV
oil cooler
One piece steel driveshaft
ID 1000cc injectors
Spec aluminum flywheel
Spec Stage 3+ clutch
Circuit sports clutch pivot
AEM Coilpacks
AEM twinfire
AEM FPR
AEM EMS
AEM Wideband
Aeroquip -6 Fuel lines
Bosch 044 inline fuel pump (fed by in-tank walbro)
Apexi boost controller
Ksport 13" front and rear brakes
I also have some work to do in the interior, and plan on stitch welding most of the car and possibly doing tubs in the front.
Shooting to get it tuned next summer, and completely finished by next fall. Still needs alot of work, but I'll be starting on the money sucking piece of metal this week, and I'll post updates as I make progress on this current monstrosity.
revolutionz_s13
'95 240sx SR20
Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
Intake mani runners before:
Intake port before:
Exhaust port before:
Intake mani runners after:
Intake port after:
exhaust port after:
cylinder side of ports after:
revolutionz_s13
'95 240sx SR20
Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
Pics!
Oil block adapter:
Xcessive windage tray (pre trimming for clearance):
Just back from the machine shop, fresh ground valve seats:
Assembling the head:
revolutionz_s13
'95 240sx SR20
So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked a**. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came 8) I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
Parts!
Cleanin a mess
Battery tray removed
A days carnage
Puttin the motor together little by little
Its gettin there slowly but surely, needs lots more time and money tho :? Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome :D
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Its gonna be a bad a** ka for sure. Keep up the good work man.
costa_rican13
Car: 1993 s13 coupe
i want to know where you keep your money tree so i can unoticably sneak and rob your tree for my ka-t build. XD
revolutionz_s13
'95 240sx SR20
LOL, its pointless, im always stripping the damn tree to buy parts, it never seems to grow money fast enough.
Razi
Car: Moo
Ballin build!
ATI dampener @_@ !
revolutionz_s13
'95 240sx SR20
yeah i hope that damn thing does its job and isnt as much of a waste of money as it seems like. i mean, its nice and all, quality of the part is there, but seriously, $600 for a damn pulley? i do like the timing marks all the way around it though...
Razi
Car: Moo
I know that Kenno (KA-T S14 Hill Climb car) has one and he said it removed a lot of vibration and that he's happy with his.
What are you plans for the exterior?
revolutionz_s13
'95 240sx SR20
I have the ssrs, a bomex front lip for the popup headlights, some sort of random side skirts, and need to get front and rear wide fenders and an apr wing and canards.
costa_rican13
Car: 1993 s13 coupe
how much did that jgs mani set you back??
revolutionz_s13
'95 240sx SR20
I think with the mani and oil line kit and a couple other little things was a little over $500
Whitecar.
Car: 1993 240sx Fastback
Very impressive! Excited to see more progress!
raven2345
Car: 91 chuki
This build is pretty legit! Good luck with it.
DamonDread
Car: 1987 Toyota Supra Turbo
Looks awesome man! Will be paying attention.
This Guy
Great work looks really good :dblthumb: Really interested to see how everything turns out
Jabberwocky
Car: 08 Subaru WRX
Nice work brother! I have been piecing together my build for about 4 years now as well, but it feels great to start putting it all together. Definately will be worth the wait, good luck with the rest!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Damn looking good
