Revolution Sensor
alex61089
Car: 1993 Infiniti J30t (crashed)
2006 Nissan Altima SL Special Ed 31K.
Hey guys im guessing my problem is the revolution sensor for my transmission so I was wondering where can i get one from? I cant seem to find any on IOS or any site so if anyone has a link or what not it would be greatly appreciated thanks
yodawill2000
Car: 94 Infiniti J30
If you call Joe at IOS he can hook you up.A lot of parts aren't listed on the website.
alex61089
do you know how much it costs?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
I wonder if that information can be found here is close enough or if the 300ZX automatic transmission is totally different.
http://www.courtesyparts.com/3....html
Maybe it's the [31935] REVOLUTION SENSOR part you need?
You have already tried running the self-diagnostic program?
Check out Figure 1 in this pdf file too.
http://www.transtec.com/rebuil...n.pdf
Modified by GerryO at 6:38 PM 4/29/2009
alex61089
It's funny because I tried doing the self diagnostics and the light doesnt even blink at all. I did everything word for word and it never seems to work, is there something i could possibly doing wrong? I installed the new TPS that i got from IOS today and to no avail. it didnt fix the problem, however, after installing it and unplugging then replugging i turned the car off and turned it back on. Guess what pops up? The At light starts blinking. and it doesnt even bother doing it again afterwords so it must be something that is on the transmission that is failing here and there, or something that is making the ECU think, oh snap, somethings wrong with the transmission.
My condition is getting worse however, when driving ( around 50mph ) the car is sort of jerking back and forth ( rpms going up and down ) and the car almost losses all of it's power when at idle ( foot on brake in drive ) and almost shuts off on me. I have to park the car, turn it off and on and off and on again about twice and then it's fine. Another symptom im having is i could have my foot on the gas steady (in about second gear) and the RPMS just shoot up to 3,000 like im stepping on the gas, only im not.
I tried to live with this but clearly it's getting worse and I love this car to death but this problem is getting the best of me I just want an explanation and a solution to what this problem is . I mean.. I cant even drive other cars now because i love the way the J feels and handles nothing compares to it I am for sure in love <3
yodawill2000
alex61089 wrote:do you know how much it costs?
Call Joe and he will tell you !!!
GerryO
Car: 1993 J30t
Pearl White
Black Interior
alex61089 wrote:It's funny because I tried doing the self diagnostics and the light doesnt even blink at all. I did everything word for word and it never seems to work, is there something i could possibly doing wrong? I installed the new TPS that i got from IOS today and to no avail. it didnt fix the problem, however, after installing it and unplugging then replugging i turned the car off and turned it back on. Guess what pops up? The At light starts blinking. and it doesnt even bother doing it again afterwords so it must be something that is on the transmission that is failing here and there, or something that is making the ECU think, oh snap, somethings wrong with the transmission.
Just for drill check the condition of the Revolution Sensor wiring and connectors, and spot their internal contact points with some dielectric grease before re-connecting them.
Based on issues I once had with my F-150 pick-up, the jerking at around 50 mph sounds more like a MAF related problem.
How long has been since the transmission fluid and filter were changed, and the transmission and cooling system flushed?
alex61089
Yeah but i replaced the MAF with a reman from napa, i dont know the last time the transmission was flushed, ect. the pan was dropped about a month and a half ago and everything seemed fine, maybe i should just get all of that stuff done? How would i drill check the rev sensor?
alex61089
dont i have to drop the transmission to get to the revolution sensor?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
By "just for drill", I meant "as a simple exercise" and I'm pretty sure revolution sensor can be replaced without dropping the transmission, but I don't know if any fluid will be lost when it's removed, which is why I suggested simply checking the wiring and connectors.
alex61089
i'll just jack this bad boy up and see what i can do
