Revolution Sensor??
Leuthesius
Car: 1996 Infiniti J30 - Totaled by Hail RIP
1995 Smurfima - Blown Head Gasket 230k miles RIP
I just took my J30 in to check for the transmission being a tad bit jumpy. They hooked their "zomgridiculuslyexpensivecadillacofcomputerscanners" up to my car, and checked the transmission. It came up with "Revolution Sensor". What the deuce? Can't find it anywhere!
Leuthesius
Also, where can I get a turbine sensor and a temp sensor for the transmission? I'm not finding these things....
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
1-888-216-5328 Ask for Joe
Leuthesius
Thanks. $118. It'll have to wait :/
driverdriver
Car: NICO's longtime resident Canuck!!!
The revolution sensor is a common part that goes on the transmission, up here it has to do with the bitter cold and hot, in other areas with age. It goes on top of the transmission. You got to drop the transmission a bit to install.
fogged306
Car: 1997 j30
Whats this revolution sensor? Different from the speed sense?.. if so whats its function.. sorry for the hijack
driverdriver
In laymans terms the revolution (also called turbine) sensor basically forces the internal clutch in an automatic transmission to upshift and downshift appropriatly based on load.
yodawill2000
Car: 94 Infiniti J30
lol
need to add that to Wilkapedia .. Classic.Sorry bout your transmission probs bro.I know on the Q forums some peeps drill through the floorboard to get to it.Anybody do that on a J ?Would beat the cheat out of pulling the transmission.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I did that on an Astro van with a 6" diameter hole saw to get to the fuel pump
Leuthesius
Here's a bit of fun. Turns out the Revolution sensor is ok. My bushings for my rear diff are bad. My rear diff is floating. :X
