Revolution Sensor
max240se
Car: 95 240sx
I did the self diagnostic procedure for the A/T and this is the result coming back....."Revolution Sensor" malfunction. i studied the FSM and i have an idea where its at but is this a hard thing to fix??? i like to DIY this but if it hard then i'll just take it to the shop.
also, what kind of transmission fluid you guys using on your A/T?
max240se
Car: 95 240sx
anyone????
pigmouse
Car: 1993 240sx Convertible
It shouldn't be hard to replace/remove. According to the FSM, you'll need to loosen the crossmember and reach up (I think it's on the passenger side).
Just look in the FSM under the transmission section. Under 'contents' of that section, there'll be a page w/instructions on how to remove it.
Good luck.
