fourdrinie »
https://forums.nicoclub.com/fourdrinie-u26512.html
Tue Mar 25, 2008 5:34 am
The FSM has a great way to interpret the flashing codes, yes it does short flash 12x with the trouble code flashing a long flash...The revolution sensor is the first flash, meaning you will get a pause between flash sets, then one long flash on the first flash, then 11 short flashes.
If you dont have the FSM, download it.I am having a problem with the revolution sensor too, but it is over-revving at idle, and making jumpy 1-2 gear shifts...I just ordered it from a junkyard for replacement.
The FSM has all the probable causes of transmission troubles in a very clear table.
